show fdb mac-tracking statistics
show fdb mac-tracking statistics {mac_addr} {no-refresh | refresh}
Description
Displays statistics for the MAC addresses that are being tracked.
Syntax Description
mac_addr Specifies a MAC address, using colon-separated bytes, for which FDB entries should be displayed.
no-refresh Specifies a static snapshot of data instead of the default dynamic display.
refresh Specifies a continuous refresh of output.
Default
N/A.
Usage Guidelines
Use the keys listed below the display to clear the statistics counters or page up or down through the table entries.
The following example displays statistics for the entries in the MAC address tracking table:
# show fdb mac-tracking statistics
MAC Tracking Statistics      Fri Mar 20 15:25:01 2009
Add         Move        Delete
MAC Address        events      events      events
00:00:00:00:00:01           0           0           0
00:00:00:00:00:02           0           0           0
00:00:00:00:00:03           0           0           0
00:00:00:00:00:04           0           0           0
00:00:00:00:00:05           0           0           0
00:00:00:00:00:06           0           0           0
00:00:00:00:00:07           0           0           0
00:00:00:00:00:08           0           0           0
00:00:00:00:00:09           0           0           0
00:00:00:00:00:10           0           0           0
00:00:00:00:00:11           0           0           0
00:00:00:00:00:12           0           0           0
00:00:00:00:00:13           0           0           0
00:00:00:00:00:14           0           0           0
00:00:00:00:00:15           0           0           0
00:00:00:00:00:16           0           0           0
00:00:00:00:00:17           0           0           0
00:00:00:00:00:18           0           0           0
0->Clear Counters  U->page up  D->page down ESC->exit
This command was first available in ExtremeXOS 12.3.
The refresh keyword was added in ExtremeXOS 16.1.
Platform Availability
